<< Click to Display Table of Contents >> CONVERT (unit conversion) |
Syntax:
CONVERT(Number, From, To)
Description:
Converts a Number between different measurement systems.
From and To are codes representing the source and the target unit (see table below).
Both units have to be in the same category. For example, you can convert meters to miles, but of course not to minutes.
A #N/A error value is displayed if a) From and To are not from the same category, or b) invalid unit codes.
Note: Unit codes are case-sensitive!
The following unit codes are available:
Mass |
Code |
Gram |
g |
Slug |
sg |
Pound* (avoirdupois) |
lbm |
u (atom mass) |
u |
Ounce (avoirdupois) |
ozm |
Distance |
Code |
Meter |
m |
Statute mile |
mi |
Nautical mile |
Nmi |
Inch |
in |
Foot |
ft |
Yard |
yd |
Ångström |
ang |
Pica |
Pica |
Light year* |
ly |
Parsec (parallax second)* |
parsec |
Time |
Code |
Second |
sec |
Minute |
mn |
Hour |
hr |
Day |
day |
Year** |
yr |
Fortnight* |
ftn |
** Based on a year with 365.25 days |
Liquid measure |
Code |
Liter |
l (lower case "L") |
Teaspoon |
tsp |
Tablespoon |
tbs |
Fluid Ounce |
oz |
Cup |
cup |
Pint (U.S.) |
pt |
Pint (U.K.) |
uk_pt |
Quart |
qt |
Gallon |
gal |
Force |
Code |
Newton |
N |
Dyne |
dyn |
Pound-force |
lbf |
Power |
Code |
Watt |
W |
HP (Horsepower) |
HP |
Magnetism |
Code |
Tesla |
T |
Gauss |
ga |
Energy |
Code |
Joule |
J |
Erg |
e |
Thermodynamic calorie |
c |
IT calorie |
cal |
Electron volt |
eV |
Horsepower-hour |
HPh |
Watt-hour |
Wh |
Foot-pound force |
flb |
BTU (British Thermal Unit) |
BTU |
Pressure |
Code |
Pascal |
Pa |
Atmosphere |
atm |
mm of Mercury |
mmHg |
Temperature |
Code |
Degree Fahrenheit |
F |
Degree Celsius |
C |
Degree Kelvin |
K |
Additionally, prefixes can be added to metric units, "mg", for instance, stands for milligrams.
Please pay attention to the capitalization here as well!
The following prefixes are available:
Prefix (and factor) |
Code |
Exa (10^18) |
E |
Peta (10^15) |
P |
Tera (10^12) |
T |
Giga (10^9) |
G |
Mega (10^6) |
M |
Kilo (1000) |
k |
Hecto (100) |
h |
Deka (10) |
e |
Deci (0.1) |
d |
Centi (0.01) |
c |
Milli (0.001) |
m |
Micro (10^-6) |
u |
Nano (10^-9) |
n |
Pico (10^-12) |
p |
Femto (10^-15) |
f |
Atto (10^-18) |
a |
Example:
CONVERT(1, "day", "sec") returns 86400 (days ‑> seconds)
CONVERT(1, "mi", "km") returns 1.60934 (miles ‑> kilometers)
CONVERT(100, "kW", "HP") returns 134.10201 (100 kW ‑> HP)
CONVERT(1, "aparsec", "cm") returns 3.08568 (Attoparsec ‑> cm)
