<< Click to Display Table of Contents >> CONVERT (unit conversion) |
Syntax:
CONVERT(Number, From, To)
Description:
This converts a Number from one unit to another.
From and To are codes that represent the source unit and target unit (see table below).
Both units have to be in the same category. For example, you can convert meters into miles but not into minutes, of course.
An error value #N/A is displayed if a) From and To are not from the same category or b) one of the two unit codes was specified incorrectly.
Note: Unit codes are case-sensitive!
The following unit codes are available:
Mass |
Code |
Gram |
g |
Slug (unit of mass) |
sg |
Pound* (avoirdupois) |
lbm |
u (atom mass) |
u |
Ounce (avoirdupois) |
ozm |
Distance |
Code |
Meter |
m |
Statute mile |
mi |
Nautical mile |
Nmi |
Inch |
in |
Foot |
ft |
Yard |
yd |
Ångström |
ang |
Pica |
Pica |
Light year |
ly |
Parsec (parallax second) |
parsec |
Time |
Code |
Second |
sec |
Minute |
mn |
Hour |
hr |
Day |
day |
Year* |
yr |
Fortnight** |
ftn |
Liquid measure |
Code |
Liter |
l (lowercase "L") |
Teaspoon |
tsp |
Tablespoon |
tbs |
Fluid ounce |
oz |
Cup |
cup |
Pint (U.S.) |
pt |
Pint (U.K.) |
uk_pt |
Quart |
qt |
Gallon |
gal |
Force |
Code |
Newton |
N |
Dyne |
dyn |
Pound-force |
lbf |
Power |
Code |
Watt |
W |
HP (Horsepower) |
HP |
Magnetism |
Code |
Tesla |
D |
Gauss |
ga |
Energy |
Code |
Joule |
J |
Erg |
e |
Thermodynamic calorie |
c |
IT calorie |
cal |
Electron volt |
eV |
Horsepower-hour |
HPh |
Watt-hour |
Wh |
Foot-pound force |
flb |
BTU (British Thermal Unit) |
BTU |
Pressure |
Code |
Pascal |
Pa |
Atmosphere |
atm |
mm of Mercury |
mmHg |
Temperature |
Code |
Degree Fahrenheit |
F |
Degree Celsius |
C |
Degree Kelvin |
K |
Furthermore, prefixes can be added to metric units, "mg", for instance, stands for milligrams.
Please pay close attention to capitalization here also!
The following prefixes are available:
Prefix (and factor) |
Code |
Exa (10^18) |
E |
Peta (10^15) |
P |
Tera (10^12) |
D |
Giga (10^9) |
G |
Mega (10^6) |
M |
Kilo (1000) |
k |
Hecto (100) |
h |
Deka (10) |
e |
Deci (0.1) |
d |
Centi (0.01) |
c |
Milli (0.001) |
m |
Micro (10^-6) |
u |
Nano (10^-9) |
n |
Pico (10^-12) |
p |
Femto (10^-15) |
f |
Atto (10^-18) |
a |
Example:
CONVERT(1, "day", "sec") returns 86400 (days ‑> seconds)
CONVERT(1, "mi", "km") returns 1.60934 (miles ‑> kilometers)
CONVERT(100, "kW", "HP") returns 134.10201 (100 kW ‑> HP)
CONVERT(1, "aparsec", "cm") returns 3.08568 (Attoparsec ‑> cm)
