PRODUCT (product)
PRODUCT (product)
Syntax:
PRODUCT(Number1 [, Number2, Number3 ...])
Description:
This returns the product of the specified numbers. Number1, Number2, etc., are the numbers to be multiplied.
Additional info:
When you use this function with cell references or arrays, text strings and logical values are ignored. However, the situation is different if you specify fixed values: Here, text strings containing numbers are counted. Furthermore, the logical value TRUE is treated as 1 and FALSE as 0. See examples below.
Example:
PRODUCT(2, 3, 4) equals 2*3*4, which is 24
When cells A1 to A3 are filled with the values 2, 3 and 4, the following applies:
PRODUCT(A1:A3) equals 2*3*4, which is 24
Note:
PRODUCT(2, "5", TRUE) equals 2*5*1, thus 10
However: If cells A1 to A3 are filled with 2, "5" and TRUE, the formula PRODUCT(A1:A3) returns a different result: It returns 2, as strings and logical values are only considered if they are specified as fixed values.
See also:
SUM
