Protecting cells and documents
PlanMaker provides several options for protecting documents or specific document contents. For example, cells can be protected from unintentional changes, or entire documents can be password-protected.
The following options are available:
▪Sheet protection
You can use sheet protection to protect specific cells in the worksheet. If sheet protection is enabled, these cells can no longer be changed and/or their content is hidden on screen or printouts.
▪Workbook protection
Use workbook protection to prevent users from adding, deleting or showing/hiding worksheets.
▪Document protection
Use document protection to password-protect the entire document against unauthorized reading or saving. If read protection is enabled, PlanMaker will additionally encrypt the document.
See the following pages for more detailed information.
