<< Click to Display Table of Contents >> Changing Presentations settings |
General settings can be changed with the ribbon command File | Options . These settings apply to all documents.
The options in the dialog box of this command are distributed by topic across multiple tabs. If you click on the Files tab, for example, you can make settings for opening and saving files.
The following pages contain detailed information on all available settings.
