<< Click to Display Table of Contents >> Converting between frame and embedded object |
You can convert a frame (for example, a picture frame) into an object that is embedded in the text (for example, a picture) at any time.
To do so, proceed as follows:
| 1. | Select the desired object. |
| 2. | Right-click on the object to open its context menu. |
| 3. | In the context menu, choose the command Convert to embedded object. |
The picture frame is now converted into an "ordinary" picture that is embedded in the text.
Of course, the reverse way is also possible: If you select an embedded object (for example, a picture) and choose the command Convert to object frame in the context menu, the picture will become a picture frame.
Tip: With the Convert button (in the group Objects) on the object-specific ribbon tab, you can also convert a frame into an embedded object and vice versa.
