Changing slide color theme and background
By default, Presentations uses a white background with black text for new presentations. However, you can add colors to the different elements of a presentation at any time. Well-coordinated color combinations can help to make a presentation both more pleasing to the eye and more memorable.
In Presentations, you can specify the colors for eight different types of elements:
▪Text and lines
▪Title text
▪Filled areas (for example, in drawings)
▪Accent
▪Shadow
▪Hyperlink
▪Hyperlink used
▪Background (see also Slide background)
You can view the color theme of a presentation with the command Design | group theme | Color theme. The dialog box displays all color themes defined in the current document and other standard color themes. Not only can you select a color theme here in order to apply it to single slides or to the entire presentation, but you can also change existing color themes or create new ones.
For more information, see the following pages.
